compression Posted August 7, 2009 Report Share Posted August 7, 2009 Well, just as I thought. 150Hp at the rear wheels just isnt enough, and I was getting a little bored with no other projects to work on. So, the 610 is going to get forced induction. The engine is going to remain a stock 1995 KA24DE (not rebuilding it) and I am going to shoot for a conservative 250-300 Hp at the rear wheels. I have been doing some research and here are my conclusions: 1. I am going to use a JGS Turbo log style manifold "kit". the kit is a setup where you weld on your own turbo flange wherever you want it. That way I can dial it in exactly for fitment in the engine bay. 2. Fast spooling T3/T4 hybrid turbo with a small-ish (.48) A/R exhaust housing. I can get a garrett with these specs for less than $500. Internal wastegate (I hate the extra plumbing with the external!) 3. 440cc/min injectors to drop in the stock fuel rail. 4. AEM engine management system (friend has one I can use, should plug right into my wiring harness). speed-density system (no MAF sensor anymore! yay!) 5. Already have a walbro 255lph fuel pump and adjustable AEM fuel pressure regulator, so that should be fine. 6. car already has a 3" mandrel bent stainless exhaust, just need to re-fab to first 2 feet of it for the down pipe. 7. The car already has an ACT clutch on it, so we will so how well it does. 8. Aluminum I/C piping I can fab no problem. For the intercooler, I had one in my garage that i think will work. I just need to massage the core support to allow the intercooler to sit inward, closer to the radiator. the 610 has a huge amount of room in the front for an intercooler, I just happened to have a huge intercooler that i am going to try to cram in there. Pipes are going to have to pass through where the high beam headlights are, so no high beams anymore. My main goal is to avoid having to seriously cut/modify the grille. I will try to update, but progress will be slow as most of my free time is now consumed by a new baby. more details on the car can be found at the link in my sig. Quote Link to comment
Skib Posted August 7, 2009 Report Share Posted August 7, 2009 that is so full of WIN Aaron :fu: Quote Link to comment
DISLEXICDIME Posted August 7, 2009 Report Share Posted August 7, 2009 you must have started missing your sr lol Quote Link to comment
bonvo Posted August 7, 2009 Report Share Posted August 7, 2009 woot!! my favorite 610 (aside from my own:fu:) is going turbo i cant wait to see the end result man Quote Link to comment
bonvo Posted August 7, 2009 Report Share Posted August 7, 2009 although if you dont want to cut the grill your gonna need a smaller intercooler 610s have alot of room up front but the grill is designed to take up most of that roomi dont know about they 74 i know my 76 didnt have it but my 73 does on the radiator support there are 2 mounting tabs one on each side that stick up to mount the grill to i find them handy for knowing how much room i have between the support and the grill i can take pics tomorrow if you like Quote Link to comment
compression Posted August 7, 2009 Author Report Share Posted August 7, 2009 (edited) although if you dont want to cut the grill your gonna need a smaller intercooler 610s have alot of room up front but the grill is designed to take up most of that roomi dont know about they 74 i know my 76 didnt have it but my 73 does on the radiator support there are 2 mounting tabs one on each side that stick up to mount the grill to i find them handy for knowing how much room i have between the support and the grill i can take pics tomorrow if you like yeah, ummm, those support tabs are gone. I cut them off. i wasnt using them anyway. The intercooler is 3" thick, so it is a little large for the space, but I will see what I can do. Might make a new intercooler, or I may just cut the whole damn core support out and build my own, I need some time to look at it closer. EDIT: Whoa! on Ebay I just found you can get a chinese intercooler for cheap! really cheap! I might have to rethink using that massive one.... Edited August 7, 2009 by compression Quote Link to comment
OpelWagenGT Posted August 8, 2009 Report Share Posted August 8, 2009 could you install headlamps with dual filiments designed to have built in high beams? Quote Link to comment
compression Posted August 8, 2009 Author Report Share Posted August 8, 2009 (edited) the low beams are BMW projector housings with H1 style HID bulbs, so no dual filament option. good idea though. i will just go without high beams, I dont do a whole lot of night driving so its not that big of an issue. Update: Chinese intercooler on the way, paid a whole $58 for it. Should fit much better than the one I have, its a little narrower and 1/2" thinner. if it doesnt work out, I am out $58, I wont lose any sleep. Edited August 8, 2009 by compression Quote Link to comment
slodat Posted August 8, 2009 Report Share Posted August 8, 2009 Looking forward to seeing this project! Nice one Aaron! Quote Link to comment
zerow Posted August 10, 2009 Report Share Posted August 10, 2009 the low beams are BMW projector housings with H1 style HID bulbs, so no dual filament option. good idea though.i will just go without high beams, I dont do a whole lot of night driving so its not that big of an issue. Update: Chinese intercooler on the way, paid a whole $58 for it. Should fit much better than the one I have, its a little narrower and 1/2" thinner. if it doesnt work out, I am out $58, I wont lose any sleep. Wait a minute - Use the high beams from the BMW setup for the low beam side. Run 9004 or 9007 dual filament bulbs. You won't have the projector setup, but you will have quad headlights that work again :) Quote Link to comment
compression Posted August 11, 2009 Author Report Share Posted August 11, 2009 (edited) No way william! :) I am not losing my projectors. I spent a huge amount of hours modifying the projector bodies, the headlight buckets, and the inner fenders of the engine bay to get those things in there! High beams go bye-bye. like I said, I consider it a non-issue as I dont really drive the car at night very much, and the projectors with the HID bulbs do a really good job of lighting up the road anyway. I appreciate the thought though! Edited August 11, 2009 by compression Quote Link to comment
zerow Posted August 15, 2009 Report Share Posted August 15, 2009 I love my quad lights, but for the sake of the new setup, go without the high beams. I modded mine up for the BMW headlights - I love the look, so I completely understand. Would I do it all again? Hell yes. I know you'll make it look good, and the function is what you need. Go Turbo! Quote Link to comment
dat521kid Posted August 15, 2009 Report Share Posted August 15, 2009 that is sweet picture of your ride Quote Link to comment
compression Posted August 17, 2009 Author Report Share Posted August 17, 2009 UPDATE: Project cancelled! No turbo for the 610! A new opportunity has emerged.... Quote Link to comment
bonvo Posted August 17, 2009 Report Share Posted August 17, 2009 :eek: please tell me the 610 stays and your not selling and or trading it Quote Link to comment
Eagle_Adam Posted January 9, 2014 Report Share Posted January 9, 2014 ummmmmmm - where the rest of this build?!!?!?!? NECRO THREAD!!!! 1 Quote Link to comment
MicroMachinery Posted March 20, 2014 Report Share Posted March 20, 2014 Here's part of it ;) http://community.ratsun.net/topic/20189-610-ka-t-u-r-b-o/ Quote Link to comment
