edekalil Posted July 11, 2023 Report Share Posted July 11, 2023 Thank you for the window bling Busta! 4 Quote Link to comment
six2ohyea Posted July 12, 2023 Report Share Posted July 12, 2023 23 hours ago, edekalil said: Thank you for the window bling Busta! That’s a cool Datlife sticker. Where did you get it? 2 Quote Link to comment
KELMO Posted July 12, 2023 Report Share Posted July 12, 2023 I'm gonna guess Busta Nut on here. Me, I prefer the 0 to 60 Eventually sticker. 2 1 Quote Link to comment
six2ohyea Posted July 12, 2023 Report Share Posted July 12, 2023 Yeah. Both are cool. @Busta Nut have any more stickers? 2 Quote Link to comment
edekalil Posted July 12, 2023 Report Share Posted July 12, 2023 1 hour ago, six2ohyea said: That’s a cool Datlife sticker. Where did you get it? BustaNut sent me them and I thank him. 1 Quote Link to comment
edekalil Posted July 12, 2023 Report Share Posted July 12, 2023 1 hour ago, KELMO said: I'm gonna guess Busta Nut on here. Me, I prefer the 0 to 60 Eventually sticker. Some girl got some in something she bought so she gave me one , looks more cool now. Quote Link to comment
edekalil Posted July 12, 2023 Report Share Posted July 12, 2023 46 minutes ago, six2ohyea said: Yeah. Both are cool. @Busta Nut have any more stickers? Not sure but I might think so . Quote Link to comment
benzo Posted July 17, 2023 Report Share Posted July 17, 2023 On 7/6/2023 at 8:35 AM, banzai510(hainz) said: I just installedsome SSR Mesh on my 510 w 510 struts. the wheel hit the strut. I called Icehouse on here and he told me to order 510 rear (Doorman brand)studs ad put them in the fron hub. I had a extra set of hubs and had a machined billet 5/16 spacer and fits perfect with lots of threads. I used a vise and a fat socket to push the studs out. installed new studs fine and fell the slines line up Wack with hammer to its set then I revered it using the Socket to push them back in. Just me here I think I would have like to see more threads going thru that wheel NUT. I think zcardepot has machined 1/4 spacers look under 280zx https://zcardepot.com/collections/wheel-related/products/wheel-spacer-1-4-4-lug-pair-240z-260z-280z?variant=39935287754865 280zx like closer to 0 offset as the hubs are 3/4 closer in the fender @banzai510(hainz) sweet you got the wheels on. I hear you on seeing more threads go through the wheel nut but it has a lot of thread on it. If I do go with a longer stud then for sure will have way more than enough of threading. There's A Dorman number shared with me 610-320 and the stud is almost 2" long and supposedly has the same knurl as the oem ones. If I swap out I'll go with these. Quote Link to comment
Busta Nut Posted July 19, 2023 Report Share Posted July 19, 2023 On 7/11/2023 at 8:58 AM, edekalil said: Thank you for the window bling Busta! No problem man................. ...............you've always kept in touch and held strong with your Datsuns....... You're a good dude.........I appreciate that...... .........you're the only one that hasn't been to the shop who has one...... ....everyone else has to come hang out for one......😄 1 Quote Link to comment
Busta Nut Posted July 19, 2023 Report Share Posted July 19, 2023 On 7/12/2023 at 9:28 AM, six2ohyea said: Yeah. Both are cool. @Busta Nut have any more stickers? I do.......come on by......😁 1 Quote Link to comment
Busta Nut Posted July 19, 2023 Report Share Posted July 19, 2023 I may have given a few away at a Canby a number of years ago....... 1 Quote Link to comment
Draker Posted July 19, 2023 Report Share Posted July 19, 2023 3 hours ago, Busta Nut said: I may have given a few away at a Canby a number of years ago....... I have one.. from Canby I think, but I've also been to the shop. 😉 Hope you and the fam are doing well. 2 Quote Link to comment
six2ohyea Posted July 20, 2023 Report Share Posted July 20, 2023 1 hour ago, Draker said: I have one.. from Canby I think, but I've also been to the shop. 😉 Hope you and the fam are doing well. Where’s his shop? 1 Quote Link to comment
Draker Posted July 20, 2023 Report Share Posted July 20, 2023 5 hours ago, six2ohyea said: Where’s his shop? North of the Golden Gate Bridge. I’d say the city but ill let him do it if he wants. 1 Quote Link to comment
edekalil Posted August 7, 2023 Report Share Posted August 7, 2023 Well finally got a bunch of bolts cleaned up and the timing cover as well. Probably will go at the cover again after I clean off any gasket material and check it out later. Quote Link to comment
Jesse C. Posted August 27, 2023 Report Share Posted August 27, 2023 So, after struggling with the FAST EFI 2.0 setup, I have given up and just yanked it out of the car. Going back to the factory Nissan harness and ECU. Sure, it will not look as clean, but, I know it runs! And I want to drive my car!!! Had to update the fuel injector plugs to the newer Xterra type, but it should be worth it. 1 Quote Link to comment
benzo Posted September 7, 2023 Report Share Posted September 7, 2023 (edited) Haven't been doing much just trying to drive the car as much but recently had an issue with cylinder #4 plug getting fouled and causing the engine to surge or run bad. Forced reason to do a compression test and check valve guide seals. The compression #'s were good and Valvetrain didn't seem to be an issue so checked the carbs and cleaned out the pilot jets and verified the sync was good. Also made a better mark on the crank pulley for easier visibility for checking timing and going to powder coat the front valance/shield since it's off. Bought a new telescopic mirror to get a better view on the carb bores to verify if I had a leaking pump nozzle or sticking/gummed up check valve. Getting more familiar with the Mikuni manual. At the time no issue. Put a new plug in that cylinder and so far the engine runs good or back to normal/pulls hard. Just going to drive it as much as I can and monitor. 0293982281444458a1bc946b9cad4a13.MOV Edited September 7, 2023 by benzo 1 Quote Link to comment
DARIN 510 Posted September 8, 2023 Report Share Posted September 8, 2023 Swapped my aftermarket trans mount for a factory Nissan one. 2 Quote Link to comment
KELMO Posted September 8, 2023 Report Share Posted September 8, 2023 That part # looks like a "Z" #, is it? And, are you using a 5 speed in this one? Sourced through a Dealer? Quote Link to comment
datzenmike Posted September 8, 2023 Report Share Posted September 8, 2023 11320-N3000 is exclusively z and zx use. Most other 71B isolators have two threaded studs that mount it to a cross member. The 510 cross member takes two bolts so... you must be using something else or modified it? Drill new holes? Quote Link to comment
KELMO Posted September 9, 2023 Report Share Posted September 9, 2023 On 9/8/2023 at 7:08 AM, datzenmike said: The 510 cross member takes two bolts so... you must be using something else or modified it? Drill new holes? Quote Link to comment
KELMO Posted September 9, 2023 Report Share Posted September 9, 2023 Not sure what happened there... Most likely using a T3 cross member or something similar. T3 has the single hole in the middle. 1 Quote Link to comment
DARIN 510 Posted September 13, 2023 Report Share Posted September 13, 2023 On 9/9/2023 at 6:29 AM, KELMO said: Not sure what happened there... Most likely using a T3 cross member or something similar. T3 has the single hole in the middle. That is correct. I’m using a crossmember similar to the T3 ones. Got it from vg30.com years ago. Yes it is an S30-S130 trans mount and I’m also using a 280zx 5 speed. 1 Quote Link to comment
iceman510 Posted September 14, 2023 Report Share Posted September 14, 2023 Dave Carroll at vg30.com was the originator of that design crossmember I think. I have one too but have not installed it yet. Intended for my 69 with a 280ZX 5 speed. Soon. I hope. 1 Quote Link to comment
KELMO Posted September 14, 2023 Report Share Posted September 14, 2023 Have the 280ZX trans and using the T3 cross member on the wagon. Ordered their universal mount but am way more interested in the OEM one. 1 Quote Link to comment
