What did you do to your dime today?
Mesh-71
  • Replies 4.2k
Added a spook!
26599921676_a873fcd303_h.jpg20160424_153829 by thomas telesco, on Flickr
26599921606_dbcb5600be_h.jpg20160424_153704 by thomas telesco, on Flickr
26599921496_a5f5012635_h.jpg20160423_144300 by thomas telesco, on Flickr
26599921506_5c40acceec_h.jpg20160423_144304 by thomas telesco, on Flickr
Drove another 250 miles today! Hooray!
Edit:    I ended up not using those allen head bolts.  Could not get the bit driver in there.  I used 7mm headed hex bolts, and was able to get'em with a cute little gear wrench.  Also siliconed the backing strips to the spoiler, as well as large round washers to the back of the apron.  Just to make things easier when I inevitably smash this thing off :)
  • Like 4
Pulled the windshield to replace the cloudy chipped up old one. Found a few minor spots of rust that need to be fixed before the new glass goes back in
I dragged out the Dremel and cleaned the spots down to bare metal. Next will be a good coating of zero rust followed by som JB Weld to fill the holes. Should be a solid fix.
Friggin photobucket is not working so no pics now.
Started "operation DIY rear seat upholstery"
Took them apart...
I was pleasantly surprised how well the seat part foam was, it was so well preserved that it didn't even smell, so I vaccumed it and will re-use...
Bought the hog ring pliers at harbor freight for $8.00
Tomorrow I'll track down the rest of the supplies and get to assemble them....
Well...I had a lot of things to get done today...but eventually got around to doing at least one part of the rear seat with the materials I picked up today, I found an almost identical fabric to my front seats....
Foam padding...
Then the finished product, by no means pro but I did it myself and it's very sturdy and comfy...
Can't wait to do the bottom part next weekend and install it :thumbup:
It still needs to be dialed in a bit, and I have a vacuum leak I need to chase down. It's running very lean at idle and it bogs just a little under 3k rpm... but it's great up top! Whoosh indeed.
Next steps: Vacuum leak, timing adjustment, and then misc. stuff like wiring in the lights so I can drive at night.
