mattyhacks71 Posted November 19, 2015 Report Share Posted November 19, 2015 Those twist connectors are just temporary, right? ;) And I've told you this before, need to slam this thing! 1 Quote Link to comment
shacks510 Posted November 20, 2015 Report Share Posted November 20, 2015 Got the roll bar painted. I used VHT "roll bar and chassis" paint. I read online that it's supposed to be some tough stuff. I would expect it to be if it's designed to go on chassis' and possibly door bars that are being rubbed on. It's the first time I've used it, and I like it a lot. Looks and feels exactly like POR15. There's definitely a different feel over normal spray paint. I would recommend it. 1 Quote Link to comment
edekalil Posted November 21, 2015 Report Share Posted November 21, 2015 Those twist connectors are just temporary, right? ;) And I've told you this before, need to slam this thing! Wire nuts temp for now and I'm working on lowering it just no time right now. Quote Link to comment
heywier427 Posted November 21, 2015 Report Share Posted November 21, 2015 Polished out my new to me, in awesome condition (thanks David!!!) rocker trim and added a black strip down the centers. Also polished small brass freeze out plugs and replaced the silver caps that came with my license plate screws. How fckin awesome would it be if I could get the classic plate to say 70-510 !!! -Edit: I can! and i will!!! 1 Quote Link to comment
heywier427 Posted November 23, 2015 Report Share Posted November 23, 2015 Added some dust protection to my camber plates. Used the cap from an oil bottle and packed it with grease. Could probably have found something that fit the over circumference, but the grease holds it in place just fine, and the stock dust cap is holding it down. Just sticky foam gasket for the rest. cause preventive maintenance. 7 Quote Link to comment
Busta Nut Posted November 23, 2015 Report Share Posted November 23, 2015 Last week....made rear moar low........ .....past couple days.... ...swapped out another stock diff and resealed the tranny......... 4 Quote Link to comment
edekalil Posted December 2, 2015 Report Share Posted December 2, 2015 Last week....made rear moar low........ .....past couple days.... ...swapped out another stock diff and resealed the tranny......... Love the shot with your dog in the foreground. 1 Quote Link to comment
edekalil Posted December 2, 2015 Report Share Posted December 2, 2015 Made a list of things to knock out on my goon. I may have posted this before but still made another one then. Tiring to focus on making it a simi dd. 2 Quote Link to comment
edekalil Posted December 6, 2015 Report Share Posted December 6, 2015 Drove her. Quote Link to comment
Anonymous Waffle Posted December 7, 2015 Report Share Posted December 7, 2015 Drove it, broke it. Jk, its back and running again. Carb needle got stuck and drowned the carb. Also new alternator, our "new" one from autozone gave out a bearing. 4 Quote Link to comment
r0p0doe Posted December 7, 2015 Report Share Posted December 7, 2015 Drove it, broke it. Jk, its back and running again. Carb needle got stuck and drowned the carb. Also new alternator, our "new" one from autozone gave out a bearing. Fuck auto zone and there lifetime warranties on shitty parts 2 Quote Link to comment
Anonymous Waffle Posted December 7, 2015 Report Share Posted December 7, 2015 Fuck auto zone and there lifetime warranties on shitty parts I had that alternator for 4 months only! I presume they thought the bearing was good and never replaced it. Quote Link to comment
r0p0doe Posted December 7, 2015 Report Share Posted December 7, 2015 I had that alternator for 4 months only! I presume they thought the bearing was good and never replaced it. Did it come with a lifetime warranty? Quote Link to comment
Anonymous Waffle Posted December 7, 2015 Report Share Posted December 7, 2015 Did it come with a lifetime warranty? Yes it did, so I got another one. The new one is real good so far, but its the Z alt so its bit bigger. But who doesnt like bigger ;) Quote Link to comment
r0p0doe Posted December 7, 2015 Report Share Posted December 7, 2015 Yes it did, so I got another one. The new one is real good so far, but its the Z alt so its bit bigger. But who doesnt like bigger ;) I have a lifetime on a starter from there and have changed it out like 5 times, once I had to do two in one week. Fuck em is the way I see it I'm going to take em back everytime Quote Link to comment
shacks510 Posted December 8, 2015 Report Share Posted December 8, 2015 I have a lifetime on a starter from there and have changed it out like 5 times, once I had to do two in one week. Fuck em is the way I see it I'm going to take em back everytime Go to the JY and try to find a factory built gear reduction. Chances are the car is there for something other than a bad starter. I have an extra in the garage just in case. I found another from a Maxima last time, but I realized it was a reman, so I left it. Every time you go to exchange your starter under warranty, you're just getting the same one back. They rebuild starters like some people "rebuild" transmissions... Quote Link to comment
russaroll Posted December 13, 2015 Report Share Posted December 13, 2015 Nothing but, my door buzzer started working all of a sudden. Quote Link to comment
q-tip Posted December 13, 2015 Report Share Posted December 13, 2015 Nothing but, my door buzzer started working all of a sudden. Mine did that for about 3 months, then stopped working again. Quote Link to comment
freekwonder Posted December 14, 2015 Report Share Posted December 14, 2015 Previous owner started to get some rust in the drivers floor board, his fix was to put some glass down. Decided it was finally time to try and fix it. Need to get some panels some where. 1 Quote Link to comment
skyblue Posted December 14, 2015 Report Share Posted December 14, 2015 Installed 1in. Sway bar. 2 Quote Link to comment
q-tip Posted December 14, 2015 Report Share Posted December 14, 2015 Previous owner started to get some rust in the drivers floor board, his fix was to put some glass down. Decided it was finally time to try and fix it. Need to get some panels some where. Mmmmm cheesy.... 1 Quote Link to comment
freekwonder Posted December 15, 2015 Report Share Posted December 15, 2015 Mmmmm cheesy.... Tried to melt it for my nachos, but didn't come out well. Surprisingly the other floor boards in the car are not that bad. Maybe a small hole hear and there, but definitely not as bad as the driver. Quote Link to comment
paradime Posted December 17, 2015 Report Share Posted December 17, 2015 Dude, that looks like compost. Definitely not nacho material. 2 Quote Link to comment
