KA Motor and trans
Looking for a swap for the dime. Let me know what you have. I will consider sohc or dohc KA motors. I would like to deal locally, im in the SF bay area.Would like a motor /w trans. even better if it is in car running, ill help you pull it out! ECU and wiring harness would be a bonus. also willing to consider a motor only ,for the right price.
  • Replies 8
Ka24e fully bolt in swap. Engine.tranny,ecu,wiring harness,crossmembers,radiator+fan. Also includes intake,header, underdrive pulleys, short shifter,and 11lb chromoly flywheel. Asking 1000. Located in portland. Only half a day away. Engine is running in the car. Thee only items I won't give up are the drive shaft and fuel pump.
very tempting... ill keep it in mind if i dont find a deal local
why you taking it out
