710's unite!!!!!!!!
  • Please log in to reply
1251 replies to this topic
#1241 datsunfreak
datsunfreak
  • Senior Member
  • 13,767 posts
  • Cars:'73 1200 Coupe, '77 280Z
Posted 15 July 2016 - 03:47 PM
Yes, but as he said, if that thing moved down, it also stops spinning the distributor.
You can not spin the distributor and simultaneously not spin the oil pump. Once that gear moves off it's intended spot, both stop spinning. The shaft itself stops spinning. There has to be a problem elsewhere...
Screenshot_2016-07-15-06-39-02_zpsc06crn
It's your car, just don't ruin it.
This seems like an elaborate ploy to get me to say "I like the D".
#1242 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,220 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 15 July 2016 - 04:40 PM
The spindle can't sit too far up inside for the oil pump to not engage it. There is just enough room between the installed distributor and oil pump for the drive spindle to fit between.
That 'gear' is an interference fit to the spindle shaft. Only way to move it is to heat with a torch and press it off, I know, I did this once.
Hammering the spindle into the oil pump is probably not a bright idea. If it didn't fit there was probably a good reason.
Posted Image
#1243 logiccreations
logiccreations
    Advanced Member
  • Members
  • PipPipPip
  • 153 posts
  • Cars:1976 datsun 710(broke)
Posted 15 July 2016 - 04:48 PM
we didnt hammer it into the pump we hit the top of the bar to push the spindle up, i understand that its "not possible" but that is what happend after we moved the gear it worked fine, but the damage was done. now back to my original question. put the 620 engine in the car or try to fix the rusted frame?
#1244 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,548 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '96 Pathfinder, too much other shite
Posted 15 July 2016 - 06:11 PM
Seems like any easy question. Do you want to drive a truck or a car?
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#1245 datzenmike
datzenmike
    KING RAT
  • 72,220 posts
Posted 15 July 2016 - 07:30 PM
If the spindle was hammered upward it would be even further from the oil pump. Hammering is no way to fix an engine. Yes, your statements make no sense at all.
If the rod bearing spun it probably was not installed properly or not torqued. They don't spin without making one hell of a noise first. You would have heard it knocking.
Posted Image
#1246 INDY510
INDY510
    Jerusalem Cruiser
  • Senior Member
  • PipPipPipPipPip
  • 9,509 posts
Posted 23 October 2016 - 08:18 PM
saw this pic on facebook .... drool:
#1247 Sastis
Sastis
    Advanced Member
  • Members
  • PipPipPip
  • 172 posts
  • Cars:78 620 KC, 70 Datsun 510 2dr, 2016 370z
Posted 14 July 2017 - 07:39 PM
photo and image hosting
#1248 Abe Froman
Abe Froman
    Member
  • Senior Member
  • PipPipPipPip
  • 1,711 posts
  • Cars:To many....
Posted 18 July 2017 - 09:52 PM
#1249 710
710
    Newbie
  • New Members
  • Pip
  • 2 posts
  • Cars:1974 Datsun 710
Posted 28 September 2017 - 10:36 AM
Hello fellow 710'ers. "710" here, a relic from the analog era (meaning I'm older than my 1974 710). Hence, my difficulties navigating the electronic world of Ratsun to find one little part you may have seen me murmur about over the lat 2 years as I  have sought to post, and answer posts in the classified (and when that didn't work emailing members with "710" somewhere in their member ID) FOR ONE PIECE OF REAR WINDOW CORNER TRIM  for my 1974 710 sedan SO I CAN GET ON WITH COMPLETING MY BODYWORK/PAINTING of the vehicle.
Can I get some love here? Even if you don't have any leads on parts?
And by the way, anybody replaced their original Hitachi carb with a Weber? I've heard that's a good thing to do on these leaky carbs, and I'm am little sick of only 18-20 mpg.
Weber site lists 3 options- the $230, $290 and $300 kits.
#1250 datzenmike
datzenmike
    KING RAT
  • 72,220 posts
Posted 28 September 2017 - 11:11 AM
A good rebuild kit is about $30 and a new Weber about 10X that. The stock carb is the best over all for everything. My L20B 710 wagon gets 29.9 US on trips. Lots of things are corrrected by just adjustments. And don't discount a good tune up for better mileage.
Posted Image
#1251 Greased monkey
Greased monkey
  • Senior Member
  • PipPipPipPip
  • 376 posts
  • Cars:74 710, hilux 4x4,2stroke jimny,turbo jimny,70 510 RHD
Posted 24 October 2017 - 05:45 AM
im pretty sure i tried to buy this from you but some reason didnt want to sell it to someone in japan :)
#1252 datzenmike
datzenmike
    KING RAT
  • 72,220 posts
Posted 24 October 2017 - 06:03 AM
Mmmmm smiley bumper....
Posted Image
