pl521sss Posted May 5, 2009 Report Share Posted May 5, 2009 1974 Datsun 620 4WD Quote Link to comment
dat521kid Posted May 5, 2009 Report Share Posted May 5, 2009 is that your new addition?? Quote Link to comment
pl521sss Posted May 5, 2009 Author Report Share Posted May 5, 2009 is that your new addition?? Yup more pics to come New radiator new weber carb EI ignition with MSD coil Runs but blown head gasket Quote Link to comment
datto510 Posted May 5, 2009 Report Share Posted May 5, 2009 Wow, nice lineup! I didn't know you had a 4 door? Did you just primer it? Quote Link to comment
pl521sss Posted May 5, 2009 Author Report Share Posted May 5, 2009 is that your new addition?? Wow, nice lineup! I didn't know you had a 4 door? Did you just primer it? 4 door is from a friend that I'm helping out. One of this weekend, will pull all my Datsuns and take pictures Picture of the engine bay How can I verify if it's a 4WD dealer install option? This will be opposite of what I've been doing, going to lift it up a bit more and taller tires Quote Link to comment
b210in Posted May 6, 2009 Report Share Posted May 6, 2009 i love it, i want one now, dam Quote Link to comment
pl521sss Posted May 7, 2009 Author Report Share Posted May 7, 2009 (edited) Love it looks mean Need advise on lift kit, wheels and tire combo Not use to doing lifted trucks, this is my first one that's running. How many variation of 4wd did the dealer use? I've seen ones with the Warn hub and I think what I have is made by Dana diff. Front cross member has been removed and a transfer case is installed. Then there's the 2 gear levers for the 4wd and low gears. I've yet to figure that how to use it. Edited May 7, 2009 by pl521sss Quote Link to comment
b210in Posted May 7, 2009 Report Share Posted May 7, 2009 if you shoot a better pick of the front diff i can tell you which one it is. lifting the truck more is easy. in this case, i would remove all the leaf springs and take them to a custom leaf spring shop, they should not charge you more than 250 to do all four of them. expect to gain about 1 to 2 inches more this way. you can always buy a lift kit, but i doubt any body makes it. the other way to get more lift from the front is to do a spring over conversion. that is move the spring on top of the alxe housing as opposed to under the housing, which is what you have. what ever route you go, you are going to have to spend some money on some good drive shafts. if you lift the it too much, you have to get a cv drive shaft other wise you are going to run in to binding and vibrations. if i were you, i would keep the lift right where it's at. remember, in the world of four wheel drive, the smaller the tire the less parts you break. from the picks, i'm guessing that the tires you have now are 31's or 30's. if you have a heavy foot and like to throttle it up dirt climbs and rocks, stick with no more than 31's. if you drive more consertive, you can possibly get away with running 32 and maybe 33's. why don't you sell it to me? Quote Link to comment
Farmer Joe Posted May 7, 2009 Report Share Posted May 7, 2009 man that truck is nice! where is everyone finding these 4x4 620s? i want one so bad. Quote Link to comment
pl521sss Posted May 7, 2009 Author Report Share Posted May 7, 2009 if you shoot a better pick of the front diff i can tell you which one it is. lifting the truck more is easy. in this case, i would remove all the leaf springs and take them to a custom leaf spring shop, they should not charge you more than 250 to do all four of them. expect to gain about 1 to 2 inches more this way. you can always buy a lift kit, but i doubt any body makes it. the other way to get more lift from the front is to do a spring over conversion. that is move the spring on top of the alxe housing as opposed to under the housing, which is what you have. what ever route you go, you are going to have to spend some money on some good drive shafts. if you lift the it too much, you have to get a cv drive shaft other wise you are going to run in to binding and vibrations. if i were you, i would keep the lift right where it's at. remember, in the world of four wheel drive, the smaller the tire the less parts you break. from the picks, i'm guessing that the tires you have now are 31's or 30's. if you have a heavy foot and like to throttle it up dirt climbs and rocks, stick with no more than 31's. if you drive more consertive, you can possibly get away with running 32 and maybe 33's. why don't you sell it to me? Can sell you my Patrol Relinquishing my interest on it What would be interesting is to mate the Patrol frame on to 620 or 521 body. Heck, why not a 410 wagon. Thanks for the advise Will keep the ride height as is Want new wheels and thinking of these ones or this one Quote Link to comment
yello620 Posted May 8, 2009 Report Share Posted May 8, 2009 Want new wheels and thinking of these ones QUOTE] I like these wheels, they would look great on a Datsun 4X. Ohh, and i agree, dont lift it anymore. Looks great like it is. Quote Link to comment
pl521sss Posted May 9, 2009 Author Report Share Posted May 9, 2009 if you shoot a better pick of the front diff i can tell you which one it is. Here's the picture of the front diff 1 Quote Link to comment
Youngblood29 Posted August 31, 2016 Report Share Posted August 31, 2016 what did you do to raise it 1 Quote Link to comment
Lockleaf Posted August 31, 2016 Report Share Posted August 31, 2016 Bah nevermind 2 Quote Link to comment
