1980 510 Napz Trans Fs5W63A 5 Speed, Flywheel / Hardware For Sale
Price - $250.00
Time Left - 8 Days, 3 Hours
Please sign in to contact advertiser directly
Transmission was removed from a 80 Datsun 510 that had the Z20/ carb engine.
The gear ratio's are 1st - 3.170, 2nd - 1.921, 3rd - 1.312, 4th - 1.000, 5th direct.
The same dogleg is used in the S10 200sx or the earlier A10 BUT with the Z series front case bolt pattern. Also same one used in the '76 and up B210 with the A series bolt up.
The Z series will fit the KA but the KA will thrash the dogleg. It's strong enough for an L or Z20, could still be used if you can find an L series front case for it.
Comes with fly wheel, hardware ( flywheel / trans to engine bolts ) , shifter & knob, boot, trans mount. I might still have the drive line, will look and update ASAP.
if you're going to Canby or know someone that is, arrangements can be made for the trans to be their. A deposit will be required.
$250.00 for pick up only.
sorry for no pic's, they are to big. Will try to get them up loaded later, if I can OR send PM me your email address.
Item Location
  • Country America
  • State or Province East Washington
  • City Clarkston
There are no public questions for this advert.
Powered by Classifieds
